Use of semantic and physical constraints in Bayesian Networks for Form Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Emilie Philippot
  • Fonction : Auteur
  • PersonId : 872145
Yolande Belaïd
Abdel Belaïd
  • Fonction : Auteur
  • PersonId : 856537
In our previous research, we worked on on-line form recognition by exploiting semantic constraints between fields using Bayesian networks. The semantic constraints allowed us to check the co-existence of fields filled up by hand by users. In this paper, we propose to test the use of architectural constraints for a design problem related to the modelling of shower areas. The proposed method exploits the physical dependencies between different parts of a space shower. The tests are performed on a database composed of 500 forms representing 5 models. The first results reach a recognition rate of 96.7%.
article_icdar_2011_version_editeur.pdf (644.08 Ko) Télécharger le fichier
inria-00629334 , version 1 (05-10-2011)
Emilie Philippot, Yolande Belaïd, Abdel Belaïd. Use of semantic and physical constraints in Bayesian Networks for Form Recognition. 11th International Conference on Document Analysis and Recognition - ICDAR 2011, International Association for Pattern Recognition, Sep 2011, Beijing, China. pp.946-950, ⟨10.1109/ICDAR.2011.192⟩. ⟨inria-00629334⟩
104 Consultations
117 Téléchargements
