Vision-based Control of 2D Plane Poiseuille Flow
This paper introduces a new approach for active fluid flows control: the vision-based approach. By using vision, dense flow velocity maps can be estimated and used in an observer-free closed-loop scheme to control a flow. This new approach is validated on a 2D plane Poiseuille flow and is proven to outperform the existing Poiseuille flow control appraches which use a limited number of available shear stress measurements.
Automatique
