s'authentifier
version française rss feed
inria-00630774, version 1
Metric graph reconstruction from noisy data
Mridul Aanjaneya () 1, Frédéric Chazal () a2, Daniel Chen () b1, Marc Glisse () 2, Leonidas J. Guibas () b1, Dmitriy Morozov () 3
27th Annual Symposium on Computational Geometry (2011) 37-46
Résumé : Many real-world data sets can be viewed of as noisy samples of special types of metric spaces called metric graphs. Building on the notions of correspondence and Gromov-Hausdorff distance in metric geometry, we describe a model for such data sets as an approximation of an underlying metric graph. We present a novel algorithm that takes as an input such a data set, and outputs the underlying metric graph with guarantees. We also implement the algorithm, and evaluate its performance on a variety of real world data sets.
  • Domaine : Informatique/Géométrie algorithmique
  • inria-00630774, version 1
  • oai:hal.inria.fr:inria-00630774
  • Contributeur :
  • Soumis le : Lundi 10 Octobre 2011, 22:58:43
  • Dernière modification le : Vendredi 6 Janvier 2012, 13:35:54
tous les articles de la base du CCSd...
