inria-00632118, version 2
Computing low-degree isogenies in genus 2 with the Dolgachev-Lehavi method
Résumé : Let ell be a prime, and H a curve of genus 2 over a field k of characteristic not 2 or ell. If S is a maximal Weil-isotropic subgroup of Jac(H)[ell], then Jac(H)/S is isomorphic to the Jacobian of some (possibly reducible) curve X. We investigate the Dolgachev--Lehavi method for constructing the curve X, simplifying their approach and making it more explicit. The result, at least for ell=3, is an efficient and easily programmable algorithm suitable for number-theoretic calculations.
- 1 : TANC (INRIA Saclay - Ile de France)
- INRIA – Polytechnique - X – CNRS : UMR7161
- Domaine : Mathématiques/Théorie des nombres
- Mots-clés : Isogeny – Jacobians – Hyperelliptic Curves – Genus 2
- Versions disponibles : v1 (13-10-2011) v2 (26-01-2012)
- inria-00632118, version 2
- http://hal.inria.fr/inria-00632118
- oai:hal.inria.fr:inria-00632118
- Contributeur : Benjamin Smith
- Soumis le : Mercredi 25 Janvier 2012, 12:58:32
- Dernière modification le : Jeudi 26 Janvier 2012, 09:28:41
Documents associés
Exporter
