Characterization of Anatomical Shape Based on Random Walk Hitting Times - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
This paper presents an implicit shape representation for describing anatomical shapes with high inter-patient variability based on the expected boundary hitting time of a random walk, which happens to be the solution to the Poisson equation. The main contribution of this paper is to test the validity of the Poisson-based mapping for learning anatomical shape variability, comparing its compactness and completeness with the commonly used Signed Distance Transform and using the liver and the caudate nucleus as examples. Based on these findings, we discuss its use as a shape prior for image segmentation.
Autre [cs.OH]
mfca08_4_2.pdf (160.97 Ko) Télécharger le fichier
inria-00632880 , version 1 (16-10-2011)
  • HAL Id : inria-00632880 , version 1
Grace Vesom, Nathan Cahill, Lena Gorelick, Alison Noble. Characterization of Anatomical Shape Based on Random Walk Hitting Times. 2nd MICCAI Workshop on Mathematical Foundations of Computational Anatomy, Oct 2008, New-York, United States. pp.117-127. ⟨inria-00632880⟩
Collections
MFCA MFCA08
111 Consultations
30 Téléchargements
