Non-linearly increasing resampling in racing algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Verena Heidrich-Meisner
  • Fonction : Auteur
  • PersonId : 912343
Christian Igel
  • Fonction : Auteur
  • PersonId : 912344
Racing algorithms are iterative methods for identifying the best among several options with high probability. The quality of each option is a random variable. It is estimated by its empirical mean and concentration bounds obtained from repeated sampling. In each iteration of a standard racing algorithm each promising option is reevaluated once before being statistically compared with its competitors. We argue that Hoeffding and empirical Bernstein races benefit from generalizing the functional dependence of the racing iteration and the number of samples per option and illustrate this on an artificial benchmark problem.
esann2011.pdf (134.19 Ko) Télécharger le fichier
inria-00633006 , version 1 (17-10-2011)
  • HAL Id : inria-00633006 , version 1
Verena Heidrich-Meisner, Christian Igel. Non-linearly increasing resampling in racing algorithms. European Symposium on Artificial Neural Networks, Apr 2011, Bruges, Belgium. pp.465-470. ⟨inria-00633006⟩
191 Consultations
119 Téléchargements
