High resolution reconstruction of a tracer dispersion event: application to ETEX - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quarterly Journal of the Royal Meteorological Society Année : 2007
In a previous two-part paper, new methods for reconstructing the source of an atmospheric tracer at regional scale were developed. Specifically, the 'maximum entropy on the mean' (MEM) method was extended to large (though linear) data assimilation problems. Tests using twin experiments and a limited subset of the data from the European Tracer Experiment (ETEX) were performed. Although temporal reconstruction knowing the location of the source was satisfying, a full three-dimensional reconstruction with real data was still out of reach. In this paper, using the MEM method and some of its refinements, a reconstruction using all ETEX-I measurements at a resolution of 1.125 × 1.125 × 1 h is shown to be possible. This allows for a reconstruction of the full dispersion event. The MEM retrieval of the tracer plume using what is believed to be a good prior is then compared to retrievals using other priors, including Gaussian priors. Eventually, a reconstruction using all data sequentially in time (rather than all together) is obtained. This helps define what a maximum-entropy filter applied to sequential data assimilation of a linear tracer should be able to do, with a view to an efficient emergency response in case of an accidental release of pollutant.
Fichier non déposé
inria-00633428 , version 1 (18-10-2011)
Marc Bocquet. High resolution reconstruction of a tracer dispersion event: application to ETEX. Quarterly Journal of the Royal Meteorological Society, 2007, 133 (625B), pp.1013-1026. ⟨10.1002/qj.64⟩. ⟨inria-00633428⟩
90 Consultations
0 Téléchargements
