A conservative method for the simulation of the isothermal Euler system with the van-der-Waals equation of state - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Scientific Computing Année : 2011
In this article, we are interested in the simulation of phase transition in compressible flows, with the isothermal Euler system, closed by the van-der-Waals model. We formulate the problem as an hyperbolic system, with a source term located at the interface between liquid and vapour. The numerical scheme is based on [1, 5]. Compared with previous discretizations of the van-der-Waals system, the novelty of this algorithm is that it is fully conservative. Its Godunov-type formulation allows an easy implementation on multidimensional unstructured meshes.
article.pdf (2.49 Mo) Télécharger le fichier
inria-00633917 , version 1 (19-10-2011)
Vincent Perrier. A conservative method for the simulation of the isothermal Euler system with the van-der-Waals equation of state. Journal of Scientific Computing, 2011, 48 (1-3), pp.296-303. ⟨10.1007/s10915-010-9415-9⟩. ⟨inria-00633917⟩
316 Consultations
255 Téléchargements
