s'authentifier
version française rss feed
inria-00634133, version 1
L'utilisation concurrente de différentes méthodes de recueil de données pour l'étude de l'activité de programmation
Willemien Visser () 1, Alexandre Morais a1
Psychologie Française 33 (1988) 127-132
Résumé : Discusses and advocates the concurrent use of several knowledge acquisition me-thods for eli-citing different types of expertise. Illustrations in the do-main of programming are pre-sented. Interviews are of particular use in the first stage of a domain study, providing general informa-tion on the organisation of the activity and topics to be investigated with other techniques. Analyzing the result of the activity, know-ledge the expert possesses may be identified, but the way it is used remains hy-pothetical. Data on this knowledge use may be gathered observing the expert in real time during his daily activity, but, as this method is very expensive, it can only be applied to a few ex-perts, and thus requires, in general, independent validation of its results. Observation in a controlled situation may cover many subjects, but on a limited number of factors and, generally, in a rather limited context. Using these methods concurrently however cancels out the disadvantages of a particular method and makes it possible to benefit from the advantages of them all.
  • Domaine : Sciences cognitives/Psychologie
  • Mots-clés : Expertise – Expert knowledge elicitation – Data gathering techniques – Programming activity – Knowledge representation – Expertise – Recueil de connaissances – Techniques de recueil de données – Activité de programmation – Représentation de connaissances
  • Commentaire : Version anglaise de ce texte : Visser – W. – & Morais – A. Concurrent use of different expertise elicitation methods applied to the study of the programming activity. In M. J. Tauber & D. Ackermann (Eds.) – Mental models and human-computer interaction 2. Amsterdam: Elsevier – 1991. Disponible en tant que INRIA Research report No. n° 0939 (1988) – accessible à http://hal.inria.fr/inria-00075619/fr/
  • inria-00634133, version 1
  • oai:hal.inria.fr:inria-00634133
  • Contributeur :
  • Soumis le : Jeudi 20 Octobre 2011, 13:47:44
  • Dernière modification le : Jeudi 15 Décembre 2011, 15:37:41
tous les articles de la base du CCSd...
