Entropy-Based Particle Systems for Shape Correspondence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents a new method for constructing statistical representations of ensembles of similar shapes. The proposed method relies on an optimal distribution of a large set of surface point correspondences, rather than the manipulation of a specific surface parameterization. The optimal configuration is defined as one in which the entropy or information content of each shape is balanced against the entropy of the ensemble of shapes. The correspondences are modeled as sets of dynamic particles that are manipulated using a gradient descent on the entropies of the shapes and the ensemble, but constrained to lie on a set of implicit surfaces. The proposed, particle-based method for finding correspondences requires very little preprocessing of data or parameter tuning, and therefore makes the problem of shape analysis more practical for a wider range of problems. This paper presents the formulation and several synthetic and real shape examples in two and three dimensions.
Autre [cs.OH]
Cates_MFCA06.pdf (608.63 Ko) Télécharger le fichier
inria-00634198 , version 1 (20-10-2011)
  • HAL Id : inria-00634198 , version 1
Joshua Cates, Miriah Meyer, Thomas Fletcher, Ross Whitaker. Entropy-Based Particle Systems for Shape Correspondence. 1st MICCAI Workshop on Mathematical Foundations of Computational Anatomy: Geometrical, Statistical and Registration Methods for Modeling Biological Shape Variability, Oct 2006, Copenhagen, Denmark. pp.90-99. ⟨inria-00634198⟩
Collections
MFCA MFCA06
164 Consultations
157 Téléchargements
