On the Strong Parity Chromatic Number - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discussiones Mathematicae Graph Theory Année : 2011
A vertex colouring of a 2-connected plane graph G is a strong parity vertex colouring if for every face f and each colour c, the number of vertices incident with f coloured by c is either zero or odd. Czap et al. [Discrete Math. 311 (2011) 512-520] proved that every 2-connected plane graph has a proper strong parity vertex colouring with at most 118 colours. In this paper we improve this upper bound for some classes of plane graphs.
CJKa11.pdf (146.72 Ko) Télécharger le fichier
inria-00634956 , version 1 (09-11-2011)
  • HAL Id : inria-00634956 , version 1
Július Czap, Stanislav Jendrol', František Kardoš. On the Strong Parity Chromatic Number. Discussiones Mathematicae Graph Theory, 2011, 31 (3), pp.587-600. ⟨inria-00634956⟩
147 Consultations
173 Téléchargements
