Singular solutions, momentum maps and computational anatomy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper describes the variational formulation of template matching problems of computational anatomy (CA); introduces the EPDiff evolution equation in the context of an analogy between CA and fluid dynamics; discusses the singular solutions for the EPDiff equation and explains why these singular solutions exist (singular momentum map). Then it draws the consequences of EPDiff for outline matching problem in CA and gives numerical examples. "I shall speak of things . . . so singular in their oddity as in some manner to instruct, or at least entertain, without wearying." - Lorenzo da Ponte
Autre [cs.OH]
Cotter_MFCA06.pdf (523.23 Ko) Télécharger le fichier
inria-00635875 , version 1 (26-10-2011)
  • HAL Id : inria-00635875 , version 1
Colin J. Cotter, Darryl D. Holm. Singular solutions, momentum maps and computational anatomy. 1st MICCAI Workshop on Mathematical Foundations of Computational Anatomy: Geometrical, Statistical and Registration Methods for Modeling Biological Shape Variability, Oct 2006, Copenhagen, Denmark. pp.18-28. ⟨inria-00635875⟩
Collections
MFCA MFCA06
45 Consultations
70 Téléchargements
