CL system: Giving instructions by corpus based selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The CL system uses an algorithm that, given a task-based corpus situated in a virtual world, which contains human instructor's speech acts and the user's responses as physical actions, generates a virtual instructor that helps a user achieve a given task in the virtual world. In this report, we explain how this algorithm can be used for generating a virtual instructor for a game-like, task-oriented virtual world such as GIVE's.
genchal2011-system-CL-benotti-denis.pdf (223.69 Ko) Télécharger le fichier
inria-00636474 , version 1 (27-10-2011)
  • HAL Id : inria-00636474 , version 1
Luciana Benotti, Alexandre A. J. Denis. CL system: Giving instructions by corpus based selection. 13th European Workshop on Natural Language Generation, Sep 2011, Nancy, France. ⟨inria-00636474⟩
133 Consultations
176 Téléchargements
