Report on the Second Second Challenge on Generating Instructions in Virtual Environments (GIVE-2.5) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
GIVE-2.5 evaluates eight natural language generation (NLG) systems that guide human users through solving a task in a virtual environment. The data is collected via the Internet, and to date, 536 interactions of subjects with one of the NLG systems have been recorded. The systems are compared using both task performance measures and subjective ratings by human users.
give25-report.pdf (1005.29 Ko) Télécharger le fichier
inria-00636498 , version 1 (27-10-2011)
  • HAL Id : inria-00636498 , version 1
Kristina Striegnitz, Alexandre A. J. Denis, Andrew Gargett, Konstantina Garoufi, Alexander Koller, et al.. Report on the Second Second Challenge on Generating Instructions in Virtual Environments (GIVE-2.5). 13th European Workshop on Natural Language Generation, Sep 2011, Nancy, France. ⟨inria-00636498⟩
195 Consultations
230 Téléchargements
