An exact algorithm for the network pricing problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Optimization Année : 2011
This work focuses on an improved exact algorithm for addressing an NP-hard network pricing problem. The method involves an efficient and partial generation of candidate solutions, a recursive scheme for generating improved upper bounds, and a column generation procedure for solving the network-structured subproblems. Its efficiency is assessed against both randomly generated instances involving three distinct topologies as well as instances based on real life situations in telecommunication and freight transportation.
inria-00638444 , version 1 (04-11-2011)
Luce Brotcorne, Fabien Cirinei, Patrice Marcotte, Gilles Savard. An exact algorithm for the network pricing problem. Discrete Optimization, 2011, 8 (2), pp.246-258. ⟨10.1016/j.disopt.2010.09.003⟩. ⟨inria-00638444⟩
106 Consultations
0 Téléchargements
