GPU-based Multi-start Local Search Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In practice, combinatorial optimization problems are complex and computationally time-intensive. Local search algorithms are powerful heuristics which allow to significantly reduce the computation time cost of the solution exploration space. In these algorithms, the multi-start model may improve the quality and the robustness of the obtained solutions. However, solving large size and time-intensive optimization problems with this model requires a large amount of computational resources. GPU computing is recently revealed as a powerful way to harness these resources. In this paper, the focus is on the multi-start model for local search algorithms on GPU. We address its re-design, implementation and associated issues related to the GPU execution context. The preliminary results demonstrate the effectiveness of the proposed approaches and their capabilities to exploit the GPU architecture.
Informatique
LION5.pdf (687.68 Ko) Télécharger le fichier
inria-00638813 , version 1 (07-11-2011)
  • HAL Id : inria-00638813 , version 1
Thé Van Luong, Nouredine Melab, El-Ghazali Talbi. GPU-based Multi-start Local Search Algorithms. Learning and Intelligent Optimization, 2011, Rome, Italy. ⟨inria-00638813⟩
139 Consultations
570 Téléchargements
