Dynamic Priority Scheduling of Periodic Tasks with Extended Precedences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The software architecture of a critical embedded control system generally consists of a set of multi-periodic communicating tasks. In order to be able to describe such a system, we define the notion of \emph{semaphore precedence constraint}, which supports multi-rate communications that follow regular repetitive patterns. We propose a feasibility test for EDF and we study three implementations, for periodic task sets related by such extended precedences on monoprocessor architectures.
main.pdf (181.99 Ko) Télécharger le fichier
inria-00638941 , version 1 (07-11-2011)
Julien Forget, Emmanuel Grolleau, Claire Pagetti, Pascal Richard. Dynamic Priority Scheduling of Periodic Tasks with Extended Precedences. IEEE 16th Conference on Emerging Technologies Factory Automation (ETFA), Sep 2011, Toulouse, France. ⟨10.1109/ETFA.2011.6059015⟩. ⟨inria-00638941⟩
210 Consultations
760 Téléchargements
