inserm-00724974, version 1
Robust Cerebral Blood Flow Map Estimation in Arterial Spin Labeling
Camille Maumet
1Pierre Maurel
1Jean-Christophe Ferré 1, 2Christian Barillot
1
International Workshop on Multimodal Brain Image Analysis (MBIA), held in conjunction with MICCAI 2012 (2012) 215-224
Résumé : Non-invasive measurement of Cerebral Blood Flow (CBF) is now feasible thanks to the introduction of Arterial Spin Labeling (ASL) Magnetic Resonance Imaging (MRI) techniques. To date, the low signal-to-noise ratio of ASL gives us no option but to repeat the acquisition in order to accumulate enough data to get a reliable signal. Perfusion signal is usually extracted by averaging across the repetitions. However, due to its zero breakdown point, the sample mean is very sensitive to outliers. A single outlier can thus have strong detrimental effects on the sample mean estimate. In this paper, we propose to estimate robust ASL CBF maps by means of M-estimators to overcome the deleterious effects of outliers. The behavior of this method is compared to z-score thresholding as recommended in [8]. validation on simulated and real data is provided. Quantitative validation is undertaken by measuring the correlation with the most widespread technique to measure perfusion with MRI: Dynamic Susceptibility weighted Contrast (DSC).
- 1 : VISAGES : Vision Action et Gestion d'Informations en Santé (VISAGES)
- INSERM : U746 – CNRS : UMR6074 – INRIA – Université de Rennes 1
- 2 : Service de radiologie et imagerie médicale [Rennes]
- CHU Rennes – Université de Rennes 1 – Hôpital Pontchaillou
- Domaine : Sciences du Vivant/Neurosciences
- inserm-00724974, version 1
- http://www.hal.inserm.fr/inserm-00724974
- oai:www.hal.inserm.fr:inserm-00724974
- Contributeur : Camille Maumet
- Soumis le : Mardi 16 Octobre 2012, 14:22:05
- Dernière modification le : Jeudi 14 Février 2013, 10:08:10
Documents associés
Exporter
