CRAC: an integrated approach to the analysis of RNA-seq reads - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Genome Biology Année : 2013
A large number of RNA-sequencing studies set out to predict mutations, splice junctions or fusion RNAs. We propose a method, CRAC, that integrates genomic locations and local coverage to enable such predictions to be made directly from RNA-seq read analysis. A k-mer profiling approach detects candidate mutations, indels and splice or chimeric junctions in each single read. CRAC increases precision compared with existing tools, reaching 99:5% for splice junctions, without losing sensitivity. Importantly, CRAC predictions improve with read length. In cancer libraries, CRAC recovered 74% of validated fusion RNAs and predicted novel recurrent chimeric junctions. CRAC is available at http://crac.gforge.inria.fr.
gb-2013-14-3-r30.pdf (446.85 Ko) Télécharger le fichier
GB-2013-14-3-R30-S1.PDF (37.85 Ko) Télécharger le fichier
GB-2013-14-3-R30-S2.PDF (487.24 Ko) Télécharger le fichier
GB-2013-14-3-R30-S3.PDF (144.23 Ko) Télécharger le fichier
GB-2013-14-3-R30-S4.PDF (431.71 Ko) Télécharger le fichier
GB-2013-14-3-R30-S5.ODS (328.19 Ko) Télécharger le fichier
gb-2013-14-3-r30.xml (131.7 Ko) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inserm-00850972 , version 1 (10-08-2013)
Nicolas Philippe, Mikaël Salson, Thérèse Commes, Eric Rivals. CRAC: an integrated approach to the analysis of RNA-seq reads. Genome Biology, 2013, 14 (3), pp.R30. ⟨10.1186/gb-2013-14-3-r30⟩. ⟨inserm-00850972⟩
1586 Consultations
1311 Téléchargements
