s'authentifier
version française rss feed
lirmm-00631528, version 1
Multiscale modeling of skeletal muscle properties and experimental validations in isometric conditions
Hassan El Makssoud 12, David Guiraud (Auteur à contacter de préférence) 12, Philippe Poignet () 12, Mitsuhiro Hayashibe 12, Pierre-Brice Wieber () 34, Ken Yoshida 56, Christine Azevedo Coste () 12
Biological Cybernetics 105 (2011) 121-138
Résumé : In this article, we describe an approach to model the electromechanical behavior of the skeletal muscle based on the Huxley formulation. We propose a model that complies with a well established macroscopic behavior of striated muscles where force-length, force-velocity, and Mirsky-Parmley properties are taken into account. These properties are introduced at themicroscopic scale and related to a tentative explanation of the phenomena. The method used integrates behavior ranging from the microscopic to the macroscopic scale, and allows the computation of the dynamics of the output force and stiffness controlled byEMG or stimulation parameters. The model can thus be used to simulate and carry out research to develop control strategies using electrical stimulation in the context of rehabilitation. Finally, through animal experiments, we estimated model parameters using a Sigma Point Kalman Filtering technique and dedicated experimental protocols in isometric conditions and demonstrated that the model can accurately simulate individual variations and thus take into account subject dependent behavior
  • Domaine : Sciences de l'ingénieur/Automatique / Robotique
    Sciences du Vivant/Ingénierie biomédicale
  • Mots-clés : Muscle model * Parameters identification * Kalman filtering * Electrical stimulation
  • lirmm-00631528, version 1
  • oai:hal-lirmm.ccsd.cnrs.fr:lirmm-00631528
  • Contributeur :
  • Soumis le : Mercredi 12 Octobre 2011, 15:52:00
  • Dernière modification le : Mercredi 12 Octobre 2011, 16:23:59
tous les articles de la base du CCSd...
