YAM++ : A multi-strategy based approach for Ontology matching task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present the capability of our ontology matching tool YAM++. We show that YAM++ is able to discover mappings between entities of given two ontologies by using machine learning approach. Besides, we also demonstrate that if the training data are not available, YAM++ can discover mappings by using information retrieval techniques. Finally, we show that YAM++ is able to deal with multi-lingual ontologies matching problem.
YAM++_A_multi_strategy_based_approach_for_Ontology_matching_task.pdf (221.49 Ko) Télécharger le fichier
lirmm-00720639 , version 1 (25-07-2012)
  • HAL Id : lirmm-00720639 , version 1
Duy Hoa Ngo, Zohra Bellahsene. YAM++ : A multi-strategy based approach for Ontology matching task. Knowledge Engineering and Knowledge Management, Oct 2012, Galway City, Ireland. pp.5. ⟨lirmm-00720639⟩
587 Consultations
1145 Téléchargements
