Evaluating the Interaction between the different Matchers (or Strategies) in Ontology Matching Task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2012
Duy Hoa Ngo
  • Fonction : Auteur
  • PersonId : 913532
Zohra Bellahsene
Ontology matching is a key solution to deal with the semantic heterogeneity problem in semantic web and data integration task. Generally, due to the high heterogeneity of ontologies, the combination of many methods are necessary to discover mappings. Then, an ontology matching tool can be seen as a set of several matching modules; each of them implementing a specific method (e.g., terminological based, structural based, semantic based, etc.). Moreover, many aspects should be taken into consideration. For example, what is the interaction between the all modules working together. In this paper, we study and evaluate with OAEI datasets two main issues such as: (i) global-based vs. local-based matching approach ; (ii) impact of input mappings on the quality of matching modules. In these experiments, we demonstrate that in element and structure based matchers, our proposed global based methods outperform the local ones and are more stable.
YAM-ExpeimentsPaper.pdf (295.2 Ko) Télécharger le fichier
lirmm-00722542 , version 1 (02-08-2012)
  • HAL Id : lirmm-00722542 , version 1
Duy Hoa Ngo, Zohra Bellahsene. Evaluating the Interaction between the different Matchers (or Strategies) in Ontology Matching Task. RR-12032, 2012, pp.12. ⟨lirmm-00722542⟩
172 Consultations
1042 Téléchargements
