An Uncertain Data Integration System
Data integration systems off er uniform access to a set of autonomous and heterogeneous data sources. An important task in setting up a data integration system is to match the attributes of the source schemas. In this paper, we propose a data integration system which uses the knowledge implied within functional dependencies for matching the source schemas. We build our system on a probabilistic data model to capture the uncertainty arising during the matching process. Our performance validation con rms the importance of functional dependencies and also using a probabilistic data model in improving the quality of schema matching. Our experimental results show significant performance gain compared to the baseline approaches. They also show that our system scales well.
2012_-_ODBASE_-_An_uncertain_Data_Integration_System.pdf (431.58 Ko)
Télécharger le fichier
