WebSmatch: a tool for Open Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Working with open data sources can yield high value information but raises major problems in terms of metadata extraction, data source integration and visualization. In this paper we describe a demonstration of WebSmatch, a flexible environment for Web data integration, based on a real, end-to-end data integration scenario over public data from Data Publica. The demonstration focuses on poorly structured input data sources (XLS files).
demoCastanier.pdf (149.5 Ko) Télécharger le fichier
lirmm-00858602 , version 1 (05-09-2013)
Emmanuel Castanier, Remi Coletta, Patrick Valduriez, Christian Frisch. WebSmatch: a tool for Open Data. WOD: Workshop on Open Data, Jun 2013, Paris, France. pp.#10, ⟨10.1145/2500410.2500420⟩. ⟨lirmm-00858602⟩
318 Consultations
766 Téléchargements
