Encryption Switching Protocols Revisited: Switching Modulo $p$ - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Laurent Imbert
Fabien Laguillaumie
At CRYPTO 2016, Couteau, Peters and Pointcheval introduced a new primitive called encryption switching protocols, allowing to switch ciphertexts between two encryption schemes. If such an ESP is built with two schemes that are respectively additively and multiplica-tively homomorphic, it naturally gives rise to a secure 2-party computation protocol. It is thus perfectly suited for evaluating functions, such as multivariate polynomials, given as arithmetic circuits. Couteau et al. built an ESP to switch between Elgamal and Paillier encryptions which do not naturally fit well together. Consequently, they had to design a clever variant of Elgamal over Z/nZ with a costly shared decryption. In this paper, we first present a conceptually simple generic construction for encryption switching protocols. We then give an efficient instantiation of our generic approach that uses two well-suited protocols, namely a variant of Elgamal in Z/pZ and the Castagnos-Laguillaumie encryption which is additively homomorphic over Z/pZ. Among other advantages, this allows to perform all computations modulo a prime p instead of an RSA modulus. Overall, our solution leads to significant reductions in the number of rounds as well as the number of bits exchanged by the parties during the interactive protocols. We also show how to extend its security to the malicious setting.
503.pdf (511.28 Ko) Télécharger le fichier
lirmm-01587451 , version 1 (14-09-2017)
Guilhem Castagnos, Laurent Imbert, Fabien Laguillaumie. Encryption Switching Protocols Revisited: Switching Modulo $p$. CRYPTO 2017, Aug 2017, Santa Barbara, United States. pp.255-287, ⟨10.1007/978-3-319-63688-7_9⟩. ⟨lirmm-01587451⟩
532 Consultations
458 Téléchargements
