Adaptation and evaluation of generic model matching strategies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2010
Une approche pour l'adaptation et l'évaluation de stratégies génériques d'alignement de modèles
Model matching is gaining importance in Model-Driven Engineering (MDE). The goal of model matching is to identify correspondences between the elements of two metamodels or two models. One of the main application scenarios is the derivation of model transformations from metamodel correspondences. Model correspondences, in turn, offer a potential to address other MDE needs. Manually finding of correspondences is labor intensive and error-prone when (meta)models are large. To automate the process, research community proposes matching strategies combining multiple heuristics. A problem is that the heuristics are limited to certain representation formalisms instead of being reusable. Another problem is the difficulty to systematically evaluate the quality of matching strategies. This work contributes an approach to deal with the mentioned issues. To promote reusability, the approach consists of strategies whose heuristics are loosely coupled to a given formalism. To systematize model matching evaluation, the approach automatically extracts a large set of modeling test cases from model repositories, and uses megamodels to guide strategy execution. We have validated the approach by developing the AML domain specific language on top of the AmmA platform. By using AML, we have implemented a library of strategies and heuristics. To demonstrate that our approach goes beyond the modeling context, we have tested our strategies on ontology test cases as well. At last, we have contributed three use cases that show the applicability of (meta)model matching to interesting MDE topics: model co-evolution, pivot metamodel evaluation, and model synchronization
L'alignement de modèles est devenu un sujet d'intérêt pour la communauté de l'Ingénierie Dirigée par les Modèles. Le but est d'identifier des correspondances entre les éléments de deux métamodèles ou de deux modèles. Un scénario d'application important est la dérivation des transformations à partir des correspondances entre métamodèles. De plus, les correspondances entre modèles offrent un grand potentiel pour adresser d'autres besoins. L'établissement manuel de ces correspondances sur des (méta)modèles de grande taille demande une grande quantité de travail et est source d'erreurs. La communauté travaille donc à automatiser le processus en proposant plusieurs stratégies d'alignement formulées comme la combinaison d'un ensemble d'heuristiques. Un premier problème est alors que ces heuristiques sont limitées à certains formalismes de représentation au lieu d'être réutilisables. Un second problème réside dans la difficulté à évaluer systématiquement la qualité des stratégies. Cette thèse propose une approche pour résoudre les problèmes ci-dessus. Cette approche développe des stratégies dont les heuristiques sont faiblement couplées aux formalismes. Elle extrait un jeu de tests d'usage à partir d'un répertoire de modèles et elle utilise finalement un mégamodèle pour automatiser l'évaluation. Pour valider cette approche, nous développons le langage dédié AML construit sur la plateforme AmmA. Nous contribuons à la définition d'une bibliothèque d'heuristiques et de stratégies AML. Pour montrer que notre approche n'est pas limitée au domaine de l'IDM nous testons celle-ci dans le domaine des ontologies. Finalement, nous proposons trois cas d'étude attestant l'applicabilité des stratégies AML dans les domaines de la coévolution des modèles, de l'évaluation des métamodèles pivots et de la synchronisation des modèles
these_GARCES.pdf (1.94 Mo) Télécharger le fichier
tel-00532926 , version 1 (04-11-2010)
  • HAL Id : tel-00532926 , version 1
Kelly Garces. Adaptation and evaluation of generic model matching strategies. Software Engineering [cs.SE]. Université de Nantes, 2010. English. ⟨NNT : ⟩. ⟨tel-00532926⟩
279 Consultations
850 Téléchargements
