Facilités de typage pour l'ingénierie des langages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Typing facilities for language engineering
The ever growing number and complexity of concerns in software intensive systems (e.g., safety, HMI, scalability, business domain concerns, etc.) leads designers of such systems to separate these concerns to deal with them independently. Model-Driven Engineering (MDE) advocates the separation of concerns in Domain-Specific Modeling Languages (DSMLs). DSMLs are used to capitalize the knowledge and know-how associated with a concern through the language constructs and its associated tools. However, both definition and tooling of a DSML require a significant development effort for a limited audience. In this thesis, we propose a relationship between models and model interfaces in order to ease the design of typing facilities for the definition and tooling of a DSML. This interface exposes the model elements and model transformations associated with a DSML. We represent such an interface by a model type supporting subtyping and inheritance relationships. For this purpose we define : a typing relationship between models and DSMLs allowing to consider models as first-class entities; subtyping relationships between DSMLs enabling the reuse of abstract syntax and model transformations.
Le nombre et la complexité toujours croissants des préoccupations prises en compte dans les systèmes logiciels complexes (e.g., sécurité, IHM, scalabilité, préoccupations du domaine d'application) poussent les concepteurs de tels systèmes à séparer ces préoccupations afin de les traiter de manière indépendante. L'ingénierie dirigée par les modèles (IDM) prône la séparation des préoccupations au sein de langages de modélisation dédiés. Les langages de modélisation dédiés permettent de capitaliser le savoir et le savoir-faire associés à une préoccupation au travers des constructions du langage et des outils associés. Cependant la définition et l'outillage d'un langage dédié demande un effort de développement important pour un public par définition réduit. Nous proposons dans cette thèse une relation liant les modèles et une interface de modèle permettant de faciliter la mise en place de facilités de typage pour la définition et l'outillage d'un langage dédié. Cette interface expose les éléments de modèle et les transformations de modèles associés à un langage de modélisation dédié. Nous représentons une telle interface par un type de modèles supportant des relations de sous-typage et d'héritage. Dans ce but nous définissons : une relation de typage entre les modèles et les langages de modélisation dédiés permettant de considérer les modèles comme des entités de première classe ; des relations de sous-typage entre langages de modélisation dédiés permettant la réutilisation de la syntaxe abstraite et des transformations de modèles.
GUY_Clement.pdf (2.19 Mo) Télécharger le fichier
tel-00917789 , version 1 (12-12-2013)
tel-00917789 , version 2 (24-04-2014)
  • HAL Id : tel-00917789 , version 2
Clément Guy. Facilités de typage pour l'ingénierie des langages. Autre [cs.OH]. Université de Rennes, 2013. Français. ⟨NNT : 2013REN1S141⟩. ⟨tel-00917789v2⟩
536 Consultations
539 Téléchargements
