Approche écologique de la mémoire épisodique dans le vieillissement normal et les neuropathologies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Naturalistic approach of Episodic memory in elderly people and neurological patients
To this day, very little is known about the way aging affects everyday episodic memory, which is a visually and contextually rich and complex memory. However, episodic memory is traditionally assessed using verbal tasks which are lacking such complexity. One of them, the California Verbal Learning Test (CVLT) uses the multi-trial free recall paradigm that we also implemented in the Human Object Memory of Everyday Scenes test using virtual reality to simulate a visit in an apartment (the HOMES test).This procedure allowed us to assess multiple memory processes such as learning, semantic clustering, proactive interference, recall versus recognition, and false recognitions. We also wanted to investigate the relationship between everyday memory and action through active navigation and its effects on each of these processes. We showed the typical profile of older adults usually obsereved using traditional paper-pencil tests on most of the memory indices except for proactive interference, which was not increased. In fact, older adults showed a reduced free recall performance despite a preserved learning ability across trials, a benefit from recognition but also a higher susceptibility to false recognitions. TBI patients (study 1) showed a profile similar to that of older adults, but patients with Alzheimer disease were impaired on all of the HOMES indices (study 2). Studies 3 and 4 examined the beneficial effect of active navigation in younger and older adults' everyday memory and showed that that recognition was the measure that benefited the most in both age groups. In contrast, older adults while active navigation decreased false recognitions in younger adults, it actually increased false recognitions in older adults. Our results on everyday memory are discussed in terms of item-specific deficit and executive deficit hypotheses in normal aging.
A ce jour, nous savons peu de choses sur la manière dont la mémoire épisodique quotidienne, visuellement riche et complexe en termes d'éléments contextuels, est affectée par le vieillissement normal contrairement aux connaissances acquises dans le domaine du vieillissement sur la mémoire épisodique verbale ou visuelle au moyens des tests traditionnels ou des procédures de laboratoire comme le paradigme de rappel libres multi-essais (e.g., utilisé par le California Verbal Learning Test). La présente thèse s'est par conséquent attachée à implémenter ce paradigme traditionnel de rappels libres multi-essais d'évaluation de la mémoire épisodique au sein d'un dispositif RV simulant une visite dans un appartement, le HOMES test (Human Objet Memory of Everyday Scenes test). Cette procédure permet de dériver des indices d'apprentissage, de catégorisation, d'interférence proactive, de bénéfice de la reconnaissance comparée au rappel libre, et de fausses reconnaissances. A cela, nous nous sommes intéressés aux relations entre la mémoire quotidienne et l'action à travers l'effet de navigation active. A l'aide d'études comparatives, nous avons retrouvé le profil mnésique classiquement observé avec le test " papier-crayon ", excepté pour l'interférence proactive qui n'est pas observée comme augmentée chez les participants âgés. En effet, des scores de rappel réduits, un bénéfice accru de la reconnaissance, une sensibilité augmentée aux fausses reconnaissances, et des capacités de regroupements sémantiques sont obtenus. Chez les jeunes adultes avec traumatisme crânien (étude 1), un profil identique est observé alors qu'un profil bien différent est obtenu auprès des patients avec maladie Alzheimer (étude 2) avec notamment un tableau associant des déficits plus marqués et des capacités de catégorisation altérées. Les études 3 et 4 adressant l'effet de navigation active chez le sujet jeune et âgé, ont mis en évidence un effet bénéfique de la navigation active sur la reconnaissance chez les deux groupes de sujets. Par contre, la navigation active diminuait les fausses reconnaissances des jeunes mais augmentait celles des âgés. Nous discutons les résultats de ces études sur la mémoire quotidienne à travers les hypothèses de déficit-item spécifique et du déclin fronto-exécutif du vieillissement normal.
ThesefinalePrashant.pdf (6.26 Mo) Télécharger le fichier
tel-00920530 , version 1 (18-12-2013)
  • HAL Id : tel-00920530 , version 1
Prashant Arvind Pala. Approche écologique de la mémoire épisodique dans le vieillissement normal et les neuropathologies. Psychologie. Université Victor Segalen - Bordeaux II, 2013. Français. ⟨NNT : ⟩. ⟨tel-00920530⟩
690 Consultations
5371 Téléchargements
