Model, exploration and estimation of consumption in dynamically reconfigurable heterogeneous architectures
Modélisation, exploration et estimation de la consommation pour les architectures hétérogènes reconfigurables dynamiquement
The use of reconfigurable accelerators when designing heterogeneous system-on-chip has the potential to increase performance and reduce energy consumption. Indeed, these accelerators are commonly a adjunct to one (or more) processor(s) and unload intensive computations and treatments. The concept of dynamic reconfiguration, supported by some FPGA vendors, allows to consider more flexible systems including the ability to sequence the execution of accelerators on the same silicon area, while reducing resource requirements. However, dynamic reconfiguration may impact overall system performance and it is hard to estimate the impact of configuration decisions on energy consumption.. The main objective of this thesis is to provide an exploration methodology to assess the impact of implementation choices of tasks of an application on a system-on-chip containing a dynamically reconfigurable resource, to optimize the energy consumption or the processing time. Therefore, we have established consumption models of reconfigurable components, particularly FPGAs, which assists the designer. Using a measurement methodology on Virtex-5, we first show the possibility to generate hardware accelerators of various sizes, execution time and energy consumption. Then, in order to quantify the implementation costs of these accelerators, we build three power models of the dynamic and partial reconfiguration. Finally, from these models, we develop an algorithm for the exploration of implementation and allocation possibilities for a complete system. Based on a high-level modeling platform, the implementation costs of the tasks and their performance on various resources (CPU or reconfigurable region) are analyzed. The solutions with the best characteristics, based on design constraints, are extracted.
L'utilisation des accélérateurs reconfigurables, pour la conception de system-on-chip hétérogènes, offre des possibilités intéressantes d'augmentation des performances et de réduction de la consommation d'énergie. En effet, ces accélérateurs sont couramment utilisés en complément d'un (ou de plusieurs) processeur(s) pour permettre de décharger celui-ci (ceux-ci) des calculs intensifs et des traitements de flots de données. Le concept de reconfiguration dynamique, supporté par certains constructeurs de FPGA, permet d'envisager des systèmes beaucoup plus flexibles en offrant notamment la possibilité de séquencer temporellement l'exécution de blocs de calcul sur la même surface de silicium, réduisant alors les besoins en ressources d'exécution. Cependant, la reconfiguration dynamique n'est pas sans impact sur les performances globales du système et il est difficile d'estimer la répercussion des décisions de configuration sur la consommation d'énergie. L'objectif principal de cette thèse consiste à proposer une méthodologie d'exploration permettant d'évaluer l'impact des choix d'implémentation des différentes tâches d'une application sur un system-on-chip contenant une ressource reconfigurable dynamiquement, en vue d'optimiser la consommation d'énergie ou le temps d'exécution. Pour cela, nous avons établi des modèles de consommation des composants reconfigurables, en particulier les FPGAs, qui permettent d'aider le concepteur dans son design. À l'aide d'une méthodologie de mesure sur Virtex-5, nous montrons dans un premier temps qu'il est possible de générer des accélérateurs matériels de tailles variées ayant des performances temporelles et énergétiques diverses. Puis, afin de quantifier les coûts d'implémentation de ces accélérateurs, nous construisons trois modèles de consommation de la reconfiguration dynamique partielle. Finalement, à partir des modèles définis et des accélérateurs produits, nous développons un algorithme d'exploration des solutions d'implémentation pour un système complet. En s'appuyant sur une plate-forme de modélisation à haut niveau, celui-ci analyse les coûts d'implémentation des tâches et leur exécution sur les différentes ressources disponibles (processeur ou région configurable). Les solutions offrant les meilleures performances en fonction des contraintes de conception sont retenues pour être exploitées.
