Intéropérabilité sémantique entre les outils de traitement d'images en neuro-imagerie - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2013
Semantic interoperability between image processing tools in neuroimaging
The field of neuroimaging research requires the ability to share, reuse and compare image processing tools coming from different laboratories. However, sharing treatment as services and composing them as workflows, is usually difficult and a complex task. This is due in most cases to the heterogeneity of services and platforms with regards to their conception and their implementation. We work within the NeuroLOG project, which aims at developing a middleware to federate data repositories and to facilitate the sharing and reuse of processing tools to analyze the shared images. It adopts an ontological approach for data and tools mediation and for sharing resources. This work aims to provide tools mediation to enhance the sharing and composition of image processing tools and provide non-specialist and expert users of neuroimaging field with an ergonomic and easy to use composition platform. We have chosen to use the Semantic Web techniques to address the various problems of resource interoperability and consistency. The first proposed solution is based on an extension of the OWL-S framework. It has been adapted to the various web services of our neuroimaging platform. We finally concluded that services that haven't the WSDL standard as descriptor could not be chained as workflow. So, we have proposed a new approach to compose image processing tools. It is based on a new ontological model for service composition that meets the requirements of the neuroimaging domain and the constraints of our domain ontology OntoNeuroLOG and addresses the various problems encountered in the development of the first approach. This work led to solve the two major problems in the composition of services; the heterogeneity of services descriptors and the interoperability of services according to the constraints within the NeuroLOG platform.
Le domaine de la recherche en neuroimagerie nécessite de pouvoir partager, réutiliser et comparer les outils de traitement d'images des différents laboratoires. Cependant la tâche de partage de traitement sous forme de services et leur composition sous forme de workflow reste une tâche difficile et trop souvent complexe. Ceci est dû dans la plupart des cas à l'hétérogénéité des services et des plateformes qui diffèrent au niveau de leurs conceptions et de leurs implémentations. Nous travaillons dans le cadre du projet NeuroLOG, une initiative cherchant à construire un système fédéré pour le partage de données et d'outils de traitement dans le domaine de la neuroimagerie. Il adopte une approche ontologique pour assurer la médiation et le partage de ressources entre les différents collaborateurs. Notre travail de thèse vise à compléter la médiation pour assurer le partage et la composition des outils de traitement d'images et à fournir aux utilisateurs spécialistes et non-spécialistes du domaine de la neuroimagerie une plateforme de composition de service ergonomique et facile à utiliser. Nous utilisons pour cela les techniques du web sémantique afin de remédier aux différents problèmes d'interopérabilité et de cohérence de ressources utilisées et produites. La première solution proposée se fonde sur une extension de la plateforme OWL-S. Elle a été adaptée aux différents services web de la plateforme de neuroimagerie. On a déduit que finalement les outils qui ne possèdent pas le format de services web et une description conforme au standard WSDL ne peuvent pas être enchaînés sous forme de workflow. A partir de là, nous avons proposé une autre approche pour effectuer la composition de services de traitement d'images. Elle se se fonde sur un nouveau modèle ontologique de composition de services qui répond aux exigences de la neuroimagerie, qui s'articule bien avec l'ontologie de domaine OntoNeuroLOG et qui pourra remédier aux différents problèmes rencontrés lors de l'élaboration de la première approche. Ce travail a permit de remédier à la fois aux problèmes d'hétérogénéité des descripteurs des services et à l'interopérabilité des services selon les contraintes de la neuroimagerie au sein de la plateforme NeuroLOG.
WALI_Bacem.pdf (4.79 Mo) Télécharger le fichier
tel-00979471 , version 1 (16-04-2014)
  • HAL Id : tel-00979471 , version 1
Bacem Wali. Intéropérabilité sémantique entre les outils de traitement d'images en neuro-imagerie. Médecine humaine et pathologie. Université de Rennes, 2013. Français. ⟨NNT : 2013REN1B003⟩. ⟨tel-00979471⟩
412 Consultations
1014 Téléchargements
