La conversion génique biaisée : origine, dynamique et intensité de la quatrième force d’évolution des génomes eucaryotes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Biased gene conversion : origin, dynamics and intensity of the fourth evolutionary force of eucaryotic genomes
Usually, three main forces are considered when studying sequences evolution in comparative genomics : mutation, selection and genetic drift. Recently, a fourth process has been identified during the study of base composition landscapes in genomes : biased gene conversion (BGC). This phenomenon introduces an overrepresentation of certain alleles in meiosis products (gametes or spores) leading to an increase of the frequency of those variants in the population. Thus, it is able to mimic and interfere with natural selection. Hence, it is important to describe this phenomenon in order to be able to trustfully distinguish BGC and selection in the study of adaptation at the molecular scale. So, the main goal of this work is to analyze the molecular origin, the intensity and the dynamics of BGC. To do so, we use two model species. First, we use the yeast Saccharomyces cerevisiae because, for this specie, a high-resolution recombination map is available which allows a fine study of the conversion process. Analyzing this map led us to shed the light on the molecular mechanisms of BGC. Secondly, recent discoveries on the role of the PRDM9 protein in the determination of recombination landscapes in mammals allowed us to quantify the dynamics and intensity of BGC in the recent human history. Thanks to those two studies, we first confirmed that BGC is the fourth force of molecular evolution and we also provided hypotheses about the evolutionary origin of this process
En génomique comparative, on considère classiquement trois forces déterminant l'évolution des séquences : la mutation, la sélection et la dérive génétique. Récemment, lors de l'étude de l'origine évolutive des variations de la composition en base des génomes, un quatrième agent a été identifié : la conversion génique biaisée (BGC). Le BGC est intimement lié à la recombinaison méiotique et semble présent chez la plupart des eucaryotes. Ce phénomène introduit une surreprésentation de certains allèles dans les produits méiotiques aboutissant à une augmentation de la fréquence de ces variants dans la population. Ce processus est capable de mimer et d'interférer avec la sélection naturelle. Il est donc important de le caractériser afin de pouvoir le distinguer efficacement de la sélection dans l'étude de l'adaptation à l'échelle moléculaire. C'est ce que nous nous attachons à faire dans le cadre de ce travail. Pour cela nous utilisons deux espèces modèles. Premièrement la levure Saccharomyces cerevisiae pour laquelle une carte de recombinaison haute résolution permettant l'analyse du processus de conversion, est disponible. L'étude approfondie de cette carte nous a permis de lever le voile sur les mécanismes moléculaires qui sous-tendent le BGC. Deuxièmement, grâce à des découvertes récentes sur la détermination des patrons de recombinaison via la protéine PRDM9 chez les mammifères, nous avons quantifié la dynamique et l'intensité de ce processus dans l'histoire évolutive récente de l'homme. Ces résultats nous ont permis de confirmer la place du BGC comme quatrième force d'évolution moléculaire, mais aussi de discuter de l'origine évolutive de ce phénomène
TH2014_Lesecque_Yann.pdf (21.86 Mo) Télécharger le fichier
tel-01064609 , version 1 (16-09-2014)
  • HAL Id : tel-01064609 , version 1
Yann Lesecque. La conversion génique biaisée : origine, dynamique et intensité de la quatrième force d’évolution des génomes eucaryotes. Génomique, Transcriptomique et Protéomique [q-bio.GN]. Université Claude Bernard - Lyon I, 2014. Français. ⟨NNT : 2014LYO10122⟩. ⟨tel-01064609⟩
806 Consultations
1242 Téléchargements
