Data driven uncertainty quantification in macroscopic traffic flow models - 3IA Côte d’Azur – Interdisciplinary Institute for Artificial Intelligence Accéder directement au contenu
Article Dans Une Revue Advances in Computational Mathematics Année : 2022
We propose a Bayesian approach for parameter uncertainty quantification in macroscopic traffic flow models from cross-sectional data. A bias term is introduced and modeled as a Gaussian process to account for the traffic flow models limitations. We validate the results comparing the error metrics of both first and second order models, showing that second order models globally perform better in reconstructing traffic quantities of interest.
UCQTFM.pdf (2 Mo) Télécharger le fichier
hal-03202124 , version 1 (19-04-2021)
hal-03202124 , version 2 (17-11-2021)
  • HAL Id : hal-03202124 , version 2
Alexandra Würth, Mickael Binois, Paola Goatin, Simone Göttlich. Data driven uncertainty quantification in macroscopic traffic flow models. Advances in Computational Mathematics, 2022, 48. ⟨hal-03202124v2⟩
550 Consultations
281 Téléchargements
