GINIP, a Gαi-Interacting Protein, Functions as a Key Modulator of Peripheral GABAB Receptor-Mediated Analgesia - ACL en SVSAE Accéder directement au contenu
Article Dans Une Revue Neuron Année : 2014
Michael Deage
  • Fonction : Auteur
Charline Kambrun
  • Fonction : Auteur
Sarah A Low
  • Fonction : Auteur
Bertrand Lambolez
Yves Le Feuvre
Emmanuel Bourinet
One feature of neuropathic pain is a reduced GABAergic inhibitory function. Nociceptors have been suggested to play a key role in this process. However, the mechanisms behind nociceptor-mediated modulation of GABA signaling remain to be elucidated. Here we describe the identification of GINIP, a Gαi-interacting protein expressed in two distinct subsets of nonpeptidergic nociceptors. GINIP null mice develop a selective and prolonged mechanical hypersensitivity in models of inflammation and neuropathy. GINIP null mice show impaired responsiveness to GABAB, but not to delta or mu opioid receptor agonist-mediated analgesia specifically in the spared nerve injury (SNI) model. Consistently, GINIP-deficient dorsal root ganglia neurons had lower baclofen-evoked inhibition of high-voltage-activated calcium channels and a defective presynaptic inhibition of lamina IIi interneurons. These results further support the role of unmyelinated C fibers in injury-induced modulation of spinal GABAergic inhibition and identify GINIP as a key modulator of peripherally evoked GABAB-receptors signaling.
PIIS0896627314007867_HAL.pdf (4.41 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-01071132 , version 1 (23-11-2018)
Paternité
Stéphane Gaillard, Laure Lo Re, Annabelle Mantilleri, Régine Hepp, Louise Urien, et al.. GINIP, a Gαi-Interacting Protein, Functions as a Key Modulator of Peripheral GABAB Receptor-Mediated Analgesia. Neuron, 2014, 84 (1), pp.123-136. ⟨10.1016/j.neuron.2014.08.056⟩. ⟨hal-01071132⟩
473 Consultations
93 Téléchargements
