Atmospheric Biodetection Part I: Study of Airborne Bacterial Concentrations from January 2018 to May 2020 at Saclay, France - ARTICLE À COMITÉ DE LECTURE EN CYTOMÉTRIE EN FLUX APPLIQUÉE À L'OCÉANOGRAPHIE ET LA MICROBIOLOGIE Accéder directement au contenu
Article Dans Une Revue International Journal of Environmental Research and Public Health Année : 2020
Background: The monitoring of bioaerosol concentrations in the air is a relevant endeavor due to potential health risks associated with exposure to such particles and in the understanding of their role in climate. In this context, the atmospheric concentrations of bacteria were measured from January 2018 to May 2020 at Saclay, France. The aim of the study was to understand the seasonality, the daily variability, and to identify the geographical origin of airborne bacteria. Methods: 880 samples were collected daily on polycarbonate filters, extracted with purified water, and analyzed using the cultivable method and flow cytometry. A source receptor model was used to identify the origin of bacteria. Results: A tri-modal seasonality was identified with the highest concentrations early in spring and over the summer season with the lowest during the winter season. Extreme changes occurred daily due to rapid changes in meteorological conditions and shifts from clean air masses to polluted ones. Conclusion: Our work points toward bacterial concentrations originating from specific seasonal-geographical ecosystems. During pollution events, bacteria appear to rise from dense urban areas or are transported long distances from their sources. This key finding should drive future actions to better control the dispersion of potential pathogens in the air, like persistent microorganisms originating from contaminated areas.
ijerph-17-06292-v2.pdf (10.76 Mo) Télécharger le fichier
hal-02969929 , version 1 (19-10-2020)
Roland Sarda-Estève, Dominique Baisnée, Benjamin Guinot, Gediminas Mainelis, John Sodeau, et al.. Atmospheric Biodetection Part I: Study of Airborne Bacterial Concentrations from January 2018 to May 2020 at Saclay, France. International Journal of Environmental Research and Public Health, 2020, 17 (17), pp.6292. ⟨10.3390/ijerph17176292⟩. ⟨hal-02969929⟩
73 Consultations
44 Téléchargements
