An extended dsRBD is required for post-transcriptional modification in human tRNAs - Traduction eucaryote Accéder directement au contenu
Article Dans Une Revue Nucleic Acids Research Année : 2015
In tRNA, dihydrouridine is a conserved modified base generated by the post-transcriptional reduction of uridine. Formation of dihydrouridine 20, located in the D-loop, is catalyzed by dihydrouridine synthase 2 (Dus2). Human Dus2 (HsDus2) expression is upreg-ulated in lung cancers, offering a growth advantage throughout its ability to interact with components of the translation apparatus and inhibit apoptosis. Here, we report the crystal structure of the individual domains of HsDus2 and their functional characterization. HsDus2 is organized into three major modules. The N-terminal catalytic domain contains the flavin cofactor involved in the reduction of uridine. The second module is the conserved ␣-helical domain known as the tRNA binding domain in HsDus2 homologues. It is connected via a flexible linker to an unusual extended version of a dsRNA binding domain (dsRBD). Enzymatic assays and yeast comple-mentation showed that the catalytic domain binds selectively NADPH but cannot reduce uridine in the absence of the dsRBD. While in Dus enzymes from bacteria, plants and fungi, tRNA binding is essentially achieved by the ␣-helical domain, we showed that in HsDus2 this function is carried out by the dsRBD. This is the first reported case of a tRNA-modifying enzyme carrying a dsRBD used to bind tRNAs.
Nucl. Acids Res.-2015-Bou-Nader-9446-56.pdf (482.25 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01279196 , version 1 (25-02-2016)
Paternité
Charles Bou-Nader, Ludovic Pecqueur, Damien Bregeon, Amina Kamah, Vincent Guérineau, et al.. An extended dsRBD is required for post-transcriptional modification in human tRNAs. Nucleic Acids Research, 2015, 43 (19), pp.9446-9456. ⟨10.1093/nar/gkv989⟩. ⟨hal-01279196⟩
590 Consultations
211 Téléchargements
