DynaLoc: Real-Time Camera Relocalization from a Single RGB Image in Dynamic Scenes based on an Adaptive Regression Forest - Immersive & Medical Technologies Lab Accéder directement au contenu
Camera relocalization is an important component in localization systems such as augmented reality or robotics when camera tracking loss occurs. It uses models built from known information of a scene. However, these models cannot perform in a dynamic environment which contains moving objects. In this paper, we propose an adaptive regression forest and apply it to our DynaLoc, a real-time camera relocalization approach from a single RGB image in dynamic environments. Our adaptive regression forest is able to fine tune and update continuously itself from evolving data in real-time. This is performed by updating a relevant subset of leaves, which gives uncertain predictions. The results of camera relocalization in dynamic scenes report that our method is able to address a large number of moving objects or a whole scene to gradually change in order to obtain high accuracy avoiding accumulation of error. Moreover, our method achieves results as accurate as the best state-of-the-art methods on static scenes dataset.
postprint_visapp_id36_dynaloc.pdf (998.8 Ko) Télécharger le fichier
hal-02392596 , version 1 (13-03-2020)
  • HAL Id : hal-02392596 , version 1
Nam-Duong Duong, Amine Kacete, Catherine Soladie, Pierre-Yves Richard, Jérôme Royan. DynaLoc: Real-Time Camera Relocalization from a Single RGB Image in Dynamic Scenes based on an Adaptive Regression Forest. 15th International Joint Conference on Computer Vision, Imaging and Computer Graphics Theory and Applications, VISIGRAPP 2020, Feb 2020, Valletta, Malta. ⟨hal-02392596⟩
474 Consultations
189 Téléchargements
