Welcome in the CEGIL (Lorraine Research Group in Multicultural German Studies) colection
CEGIL is made up of specialists in German, Austrian, Scandinavian and Dutch literature, history of ideas and civilization (15th-21st c.).
It ranks among the leading groups in its field – on a national and an international basis – which makes it possible to set up network projects with MSH Lorraine (Lorraine Center for the Sciences of Man) and the ANR (the National Research Agency), as well as other international partners. CEGIL research – linking up 3 main notions (identities - genres; frontiers - margins; networks - exchange) – is dedicated to the study of interdisciplinary and multicultural theories and practices.
Using all types of documents – including periodicals – this research is principally oriented along the study of transfers, communication, exchanges and interaction between different environments and cultures. Thanks also to its collaboration with non-academic institutions, CEGIL gives the larger public general access to the results of its research.
Latest deposited documents
Chargement de la page
Search
Deposit figures
