Microstructures et propriétés mécaniques des alliages de type Duralumin du Breguet 765 n°504 64-PH : approche historique et sciences des matériaux - Thèses et HDR du Centre d’Élaboration de Matériaux et d’Etudes Structurales Accéder directement au contenu
Thèse Année : 2016
Microstructures and mechanical properties of Duralumin alloys of the Breguet 765 n°504
Industrially produced since 1910 and used for the construction of Breguet XIV in 1916, the duralumins (Al-Cu-Mg alloys) are the first age-hardening aluminum alloys that were at the origin of the aeronautics development. Although Al-Zn-Cu alloys of the 7xxx family and composite materials are more widely used today, these Al-Cu-Mg alloys of the 2xxx family remain a reference material for aircraft structures. However, although it is an industrial material, with a large production of written documents, the archiving policy applied by manufacturers causes a loss of information. There is thus a difficulty to retrieve pertinent chemical and physical data of material used in aircraft construction, but also to understand the choices made about the material and process used by the manufacturers. The renovation of the Breguet 765 Sahara n°504 64-PH by the association Ailes Anciennes Toulouse is an opportunity to study aeronautical duralumins of the late 1950s. It is possible to recover elements need to be replaced before they are permanently lost, with the information contained therein. By comparing laboratory analysis with archival and current literature, it is possible to give a feedback on these ancient materials. We can compare what was done with what was originally planned in the design of the aircraft and complete the known data of these materials with current metallurgical technical analysis. These alloys can also be a first reference for aeronautical duralumins of the 1950s and contribute to the study of the long-term evolution of mechanical properties compared to minimum values ??required by the manufacturer.
Produits industriellement dès 1910, les duralumins (alliages Al-Cu-Mg) sont les premiers alliages d'aluminium à durcissement structural ayant permis le développement de l'aéronautique. Bien que les alliages Al-Zn-Cu de la famille 7xxx et les matériaux composites soient aujourd'hui majoritaires dans la construction des avions, ces alliages Al-Cu-Mg de la famille 2xxx restent un matériau de référence pour les structures aéronautiques. Cependant, même s'il est un produit industriel récent et largement utilisé, avec une grande production de documents écrits, il existe une perte d'informations liée à la politique d'archives appliquée par les industriels. Cette perte d'information touche particulièrement les données physico-chimiques des matériaux utilisés pour la construction des avions mais aussi l'explication des choix techniques des avionneurs. La rénovation du Breguet 765 Sahara n°504 64-PH aux Ailes Anciennes Toulouse est une opportunité d'étudier les duralumins aéronautiques de la fin des années 1950. Il est possible de récupérer les pièces déposées et remplacées avant qu'elles ne soient jetées et définitivement perdues avec les informations qu'elles contiennent. En comparant l'analyse en laboratoire de ces matériaux arrivés jusqu'à nous avec les documents d'archives et la documentation actuelle, il est possible d'entreprendre un retour sur expérience. Nous pouvons envisager de comparer ce qui a été réalisé avec ce qui a été initialement prévu lors de la conception de l'avion et de compléter les données connues de ces matériaux avec les techniques d'analyses métallurgiques actuelles. Ces alliages peuvent également constituer une première référence des duralumins aéronautiques des années 1950 et contribuer à l'étude de l'évolution sur de grandes échelles de temps des propriétés mécaniques par rapport aux valeurs minimum exigées du constructeur.
2016TOU30384b.pdf (6.47 Mo) Télécharger le fichier
tel-01760733 , version 1 (06-04-2018)
  • HAL Id : tel-01760733 , version 1
Audrey Cochard. Microstructures et propriétés mécaniques des alliages de type Duralumin du Breguet 765 n°504 64-PH : approche historique et sciences des matériaux. Matériaux. Université Paul Sabatier - Toulouse III, 2016. Français. ⟨NNT : 2016TOU30384⟩. ⟨tel-01760733⟩
322 Consultations
6024 Téléchargements
