The development of student's early number sense - Algebraic thinking Accéder directement au contenu
The present study adopted a theoretical model, suggesting that number sense consists of elementary number sense, conventional arithmetic and algebraic arithmetic , to trace the development of students' early number sense. Two hundred and four 1 st grade students were individually tested on five time-points. Data analysis suggested that number sense follows a linear growth rate and six groups of students were identified that follow different growth patterns. Two of the groups had a low initial value, two had a moderate initial value and two had high initial value. Systematically, one of the two groups with the same initial value exhibited a greater growth rate. The gap of the groups with same initial value in algebraic arithmetic progressively increased across the five time-points of the study.
CERME9.TWG03.12.papers.Pittalis.pdf (499.9 Ko) Télécharger le fichier
hal-01286931 , version 1 (11-03-2016)
  • HAL Id : hal-01286931 , version 1
Marios Pittalis, Demetra Pitta-Pantazi, Constantinos Christou. The development of student's early number sense. CERME 9 - Ninth Congress of the European Society for Research in Mathematics Education, Charles University in Prague, Faculty of Education; ERME, Feb 2015, Prague, Czech Republic. pp.446-452. ⟨hal-01286931⟩
184 Consultations
828 Téléchargements
