MATAM: reconstruction of phylogenetic marker genes from short sequencing reads in metagenomes - CRISTAL-BONSAI Accéder directement au contenu
Article Dans Une Revue Bioinformatics Année : 2017
Motivation: Advances in the sequencing of uncultured environmental samples, dubbed metagenomics, raise a growing need for accurate taxonomic assignment. Accurate identification of organisms present within a community is essential to understanding even the most elementary ecosystems. However, current high-throughput sequencing technologies generate short reads which partially cover full-length marker genes and this poses difficult bioinformatic challenges for taxonomy identification at high resolution. Results: We designed MATAM, a software dedicated to the fast and accurate targeted assembly of short reads sequenced from a genomic marker of interest. The method implements a stepwise process based on construction and analysis of a read overlap graph. It is applied to the assembly of 16S rRNA markers and is validated on simulated, synthetic and genuine metagenomes. We show that MATAM outperforms other available methods in terms of low error rates and recovered fractions and is suitable to provide improved assemblies for precise taxonomic assignments.
main.pdf (1.63 Mo) Télécharger le fichier
hal-01646297 , version 1 (16-01-2018)
hal-01646297 , version 2 (01-10-2019)
Pierre Pericard, Yoann Dufresne, Loïc Couderc, Samuel Blanquart, Hélène Touzet. MATAM: reconstruction of phylogenetic marker genes from short sequencing reads in metagenomes. Bioinformatics, 2017, ⟨10.1093/bioinformatics/btx644⟩. ⟨hal-01646297v1⟩
Collections
CRISTAL-BONSAI CMM
332 Consultations
348 Téléchargements
