L'accompagnement associatif vers l'emploi : le cas des Personnes vivant avec le VIH - CV des membres de ERUDITE Accéder directement au contenu
Thèse Année : 2013
The Community support towards employment : the case of People living with Aids
This thesis proposes a socio-economic analysis of the support provided in the associative sector to People living with HIV when looking for a job in France. On the one hand, it studies how the associative support is built and on the other hand how access-to-job paths integrates in the associative landscape. By opening the black box of the social accompanying, it completes the statistical and biographical approaches of support relationship that are built by the associative instituion through two monographs. Based on the coupling institutionalized theory, the stakeholders's text analysis - using the software Alceste - identifies the institutional part with regards to social construction in the access-to-job paths and shows a tension between deliberation and access-to-job within the associative support construction. The contextualized biographical analysis identifies the institutional factors of failure and access-to-job success. The speakability release and the skills that are acquired with the experience make easier and reinforce the access-to-job when social problems and attitude towards AIDS undermines it. Those analyses show that the associative support towards employment added-value includes the support relationship under collective dynamics by making it less individual, building deliberation arenas and by valuing the experiental knowledge.The thesis finally shows that associative instituions are difficult to modify and that the practises withstand to institutional changes dynamics while get nourished by it.
Cette thèse propose une analyse socioéconomique de l'accompagnement associatif des Personnes vivant avec le VIH (PvVIH) vers l'emploi en France. Elle étudie la construction de l'accompagnement associatif d'une part et l'inscription des trajectoires d'accès à l'emploi dans l'espace associatif d'autre part. Complétant les approches statistique et biographique de l'accompagnement vers l'emploi en ouvrant la boîte noire de l'accompagnement, elle analyse la relation d'accompagnement construite par l'institution associative à travers deux monographies. S'appuyant sur la théorie institutionnaliste du couplage, l'analyse textuelle du langage des acteurs, réalisée à l'aide du logiciel Alceste, identifie la part institutionnelle dans la construction sociale des trajectoires d'accès à l'emploi et montre une tension entre délibération et accès à l'emploi dans la construction de l'accompagnement associatif. L'analyse biographique contextualisée repère les facteurs institutionnels d'échec et de réussite dans l'accès à l'emploi. La libération de la dicibilité et l'acquisition de compétence sur le modèle de l'expertise d'usage facilitent et consolident l'accès à l'emploi quand les difficultés sociales et le regard social sur le VIH/sida le freinent et le fragilisent. Ces analyses montrent que la valeur ajoutée de l'accompagnement associatif vers l'emploi est d'inscrire la relation d'accompagnement dans une dynamique collective en la désindividualisant, en mettant en place des espaces de délibération et en valorisant les savoirs d'expériences. La thèse montre finalement que les institutions associatives sont difficiles à modifier et que les pratiques résistent aux dynamiques de changements institutionnels tout en s'en nourrissant.
28071_CERVERA_2013_archivage.pdf.pdf.pdf.pdf (9.66 Mo) Télécharger le fichier
tel-00985189 , version 1 (29-04-2014)
  • HAL Id : tel-00985189 , version 1
Melaine Cervera. L'accompagnement associatif vers l'emploi : le cas des Personnes vivant avec le VIH. Economies et finances. Université Paris-Est, 2013. Français. ⟨NNT : 2013PEST0071⟩. ⟨tel-00985189⟩
644 Consultations
2071 Téléchargements
