index - IRFU Accéder directement au contenu
NOMBRE DE TEXTES INTEGRAUX
3 480
NOMBRE DE NOTICES
10 632
OPEN ACCESS
87 %
EVOLUTION DES DEPOTS
MOTS CLES
Numerical calculations Monte Carlo Nucleus Galaxies high-redshift Mass dependence Galaxies ISM TeV 13000 GeV-cms Neutrino oscillation CERN Lab X-rays binaries Transverse momentum dependence Rapidity dependence Galaxy Bolometer Particle Physics Experiments Background P p scattering Cavity Accretion Top pair production Galaxies star formation ATLAS Kinematics Correlation Performance Bottom particle identification Muon Final state njet dilepton Electron Cosmology observations Galaxies clusters general 5020 GeV-cms/nucleon New physics search for Galaxies evolution Gravitation Galaxies active Double-beta decay 0neutrino HESS Z0 leptonic decay Perturbation theory higher-order Hadron-Hadron scattering experiments Data analysis method Lepton Supersymmetry Hadron-Hadron Scattering Higgs particle hadronic decay Cosmic rays New physics Detector design Effective field theory Quantum chromodynamics perturbation theory Phase space Parton distribution function Resonance production Coupling constant upper limit Large-scale structure of Universe Rapidity Sensitivity 8000 GeV-cms Astrophysics Muon pair production Bottom pair production Higher-order 1 Stars formation Hydrodynamics Dark matter Cosmic background radiation CMS ALICE Electroweak interaction Electron pair production Structure Quantum chromodynamics Photon Channel cross section measured Beyond Standard Model P p colliding beams Higgs particle hadroproduction Statistical analysis Cosmology ISM clouds Methods data analysis Transverse momentum Channel cross section upper limit Experimental results Signature Numerical calculations Differential cross section measured Transverse momentum missing-energy CERN LHC Coll Final state njet lepton Monte Carlo GLAST GeV Channel cross section branching ratio upper limit Activity report Jet bottom Methods numerical Surveys Heavy ion scattering
