Non destructive examination of immersed structures within liquid sodium
The In Service Inspection of internal structures of future liquid sodium cooled fast reactors implies, among different options, the use of ultrasounds from the outside of sodium circuit. In these conditions, ultrasounds have to propagate through the metallic envelope of main vessel, then other immersed plates. Thus the study aims at mastering ultrasonic propagation in these multilayered structures in order to determine the best conditions allowing NDT of a plate behind some screens. The necessity of propagating a maximum of energy through bounded media orientated the study towards Lamb waves. Those are often employed for singles plates or solid layers but they are less usual for liquid/solid alternations. Theoretical results are obtained using transfer matrix method. They are compared to in water experimental measurements. Cases with one, two and three parallel plates without then with an artificial defect are presented for identical and different thicknesses of plates. Results show that an artificial crack defect is obviously detected in a plate located behind one and two screens. Measured attenuation is compatible with industrial NDT conditions. Thus a promising potential is shown for this inspection technique.
Mots clés
Ultrasonic variables measurement
Ultrasonic imaging
Transfer Matrix Method
steel
nuclear reactors
nondestructive testing
nondestructive examination
metallic envelope
sodium circuit
parallel plates
Acoustics
fusion reactor materials
Inductors
inspection
internal structures
lamb waves
liquid metal fast breeder reactors
liquid sodium
Maintenance engineering
main vessel
sodium
