Asymptotic behavior for the Vlasov-Poisson equations with strong uniform magnetic field and general initial conditions - Ecole Centrale de Marseille Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Mihai Bostan
  • Fonction : Auteur
  • PersonId : 837137
main_VlaPoiGyr2D_2.pdf (289.89 Ko) Télécharger le fichier
hal-02310174 , version 1 (09-10-2019)
  • HAL Id : hal-02310174 , version 1
Mihai Bostan. Asymptotic behavior for the Vlasov-Poisson equations with strong uniform magnetic field and general initial conditions. 2019. ⟨hal-02310174⟩
84 Consultations
93 Téléchargements
