Eliminating Cuts in hoI(C ) - Extended Abstract - Recherche en informatique (CRI)
 Accéder directement au contenu
We discuss the problem of cut elimination in an intuitionistic version of Church's Type Theory with constraints, a problem that arises in considering executable fragments suitable for logic programming.
A-732.pdf (128.86 Ko) Télécharger le fichier
hal-02958328 , version 1 (05-10-2020)
  • HAL Id : hal-02958328 , version 1
Olivier Hermant, James Lipton. Eliminating Cuts in hoI(C ) - Extended Abstract. TEASE-LP: Workshop on Trends, Extensions, Applications and Semantics of Logic Programming, May 2020, Paris, France. ⟨hal-02958328⟩
22 Consultations
21 Téléchargements
