Skip to Main content
Skip to Navigation
HAL
HAL
HALSHS
TEL
MédiHAL
Liste des portails
AURéHAL
API
Data
Documentation
Episciences.org
Episciences.org
Journals
Documentation
Sciencesconf.org
Support
Sign in with ORCID
se connecter avec Fédération
Create account
Forgot your password?
Have you forgotten your login?
fr
en
Matériaux (MAT)
Home
Browse
Document list
List by subject
List by authors
Search
Home
Last submissions
Aldo Marano, Lionel Gélébart, Samuel Forest. FFT-based simulations of slip and kink bands formation in 3D polycrystals: influence of strain gradient crystal plasticity. 2021. ⟨hal-03104411⟩
Aurélien Fouque, Georges Cailletaud, Vladimir A. Esin, Romaric Landfried, Philippe Testé, et al.. Observation of metallurgical changes induced by an electric arc to Ag-SnO2-CuO electrodes. 65th IEEE Holm Conference on Electrical Contacts, Sep 2019, Milwaukee, United States. pp.239-244, ⟨10.1109/HOLM.2019.8923681⟩. ⟨hal-02155532⟩
Thomas Tancogne-Dejean, Christian Roth, Thilo Morgeneyer, Lukas Helfen, Dirk Mohr. Ductile damage of AA2024-T3 under shear loading: Mechanism analysis through in-situ laminography. Acta Materialia, Elsevier, 2021, 205, pp.116556. ⟨10.1016/j.actamat.2020.116556⟩. ⟨hal-03098188⟩
Adrien Emery. Corrosion intergranulaire des aciers inoxydables austénitiques en milieu acide nitrique oxydant. Matériaux. Université Paris sciences et lettres, 2020. Français. ⟨NNT : 2020UPSLM031⟩. ⟨tel-03097345⟩
Julien Said, Siegfried Fouvry, Georges Cailletaud, Christine Yang, Fikri Hafid. Shear driven crack arrest investigation under compressive state: Prediction of fretting fatigue failure of aluminium strands. International Journal of Fatigue, Elsevier, 2020, 136, pp.105589. ⟨10.1016/j.ijfatigue.2020.105589⟩. ⟨hal-03093096⟩
J. Said, S. Garcin, S. Fouvry, G. Cailletaud, C. Yang, et al.. A multi-scale strategy to predict fretting-fatigue endurance of overhead conductors. Tribology International, Elsevier, 2020, 143, pp.106053. ⟨10.1016/j.triboint.2019.106053⟩. ⟨hal-03093081⟩
François Willot. The effective conductivity of strongly nonlinear media: The dilute limit. International Journal of Solids and Structures, Elsevier, 2020, Special Issue on Physics and Mechanics of Random Structures: From Morphology to Material Properties, 184, pp.287-295. ⟨10.1016/j.ijsolstr.2019.06.006⟩. ⟨hal-02425307⟩
Matthias Neumann, Ole Stenzel, François Willot, Lorenz Holzer, Volker Schmidt. Quantifying the influence of microstructure on effective conductivity and permeability: Virtual materials testing. International Journal of Solids and Structures, Elsevier, 2020, Special Issue on Physics and Mechanics of Random Structures: From Morphology to Material Properties, 184, pp.211-220. ⟨10.1016/j.ijsolstr.2019.03.028⟩. ⟨hal-02425310⟩
H. Launay, J. Besson, D. Ryckelynck, François Willot. Hyper-reduced arc-length algorithm for stability analysis in elastoplasticity. International Journal of Solids and Structures, Elsevier, 2021, 208-209, pp.167-180. ⟨10.1016/j.ijsolstr.2020.10.014⟩. ⟨hal-03088229⟩
Vincent Bortolussi, Bruno Figliuzzi, François Willot, Matthieu Faessel, Michel Jeandin. Electrical Conductivity of Metal–Polymer Cold Spray Composite Coatings onto Carbon Fiber-Reinforced Polymer. Journal of Thermal Spray Technology, ASM International/Springer, 2020, 29 (4), pp.642-656. ⟨10.1007/s11666-020-00999-7⟩. ⟨hal-03087970⟩
Rim Ben Toumi. Endommagement par fatigue et durée de vie de structures en matériaux composites à fibres continues pour application liaison au sol. Matériaux. Ecole Nationale Supérieure des Mines de Paris, 2015. Français. ⟨NNT : 2015ENMP0064⟩. ⟨tel-03081259⟩
Qingdong Yin. Influence de la composition chimique sur la formation de la microstructure et les caractéristiques mécaniques de soudures en aciers emboutissables à chaud. Matériaux. Ecole Nationale Supérieure des Mines de Paris, 2015. Français. ⟨NNT : 2015ENMP0088⟩. ⟨tel-03081220⟩
Geoffrey Bégué. Etude de l'adhérence de barrière thermique EB-PVD par choc laser (LASAT) pour le développement d'un contrôle non-destructif sur aube de turbine aéronautique. Matériaux. Ecole Nationale Supérieure des Mines de Paris, 2015. Français. ⟨NNT : 2015ENMP0093⟩. ⟨tel-03081137⟩
Joseph Djouda, Mohamed Bouaziz, Marouene Zouaoui, Matthieu Rambaudon, Julien Gardan, et al.. Experimental method for microscale mechanical characterization of polymeric pre-structured materials manufactured by Fused Deposition Modelling. Polymer Testing, Elsevier, 2020. ⟨hal-03070424⟩
Joseph Marae Djouda, Donato Gallittelli, Marouene Zouaoui, Ali Makke, Julien Gardan, et al.. Local scale fracture characterization of an advanced structured material manufactured by fused deposition modeling in 3D printing.. Frattura ed Integrità Strutturale / Fracture and Structural Integrity, Università di Cassino, 2019, 51, pp.534 - 540. ⟨10.3221/igf-esis.51.40⟩. ⟨hal-03050669⟩
Clément Cadet, Jacques Besson, Sylvain Flouriot, Samuel Forest, Pierre Kerfriden, et al.. Ductile Fracture of Materials with Randomly Distributed Defects. 2020. ⟨hal-03038262⟩
Guillaume Cottin, Vincent Guipont, Vincent Maurel, Emine Bakan, Robert Vaßen, et al.. Development of Environmental Barrier Coatings on Ceramic Matric Composites assisted by LASAT (Laser Shock Adhesion Test). HT-CMC, Sep 2019, Bordeaux, France. ⟨hal-02185840⟩
Youssef Hammadi. Réduction d'un modèle 0D instationnaire et non-linéaire de thermique habitacle pour l'optimisation énergétique des véhicules automobiles. Thermique [physics.class-ph]. Université Paris sciences et lettres, 2020. Français. ⟨NNT : 2020UPSLM027⟩. ⟨tel-03012674⟩
Henry Proudhon, Maxime Pelerin, Andrew King, Wolfgang Ludwig. In situ 4D mechanical testing of structural materials: The data challenge. Current Opinion in Solid State and Materials Science, Elsevier, 2020, pp.100834. ⟨10.1016/j.cossms.2020.100834⟩. ⟨hal-02926097⟩
Samuel Forest. Continuum thermomechanics of nonlinear micromorphic, strain and stress gradient media. Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, Royal Society, The, 2020, 378 (2170), pp.20190169. ⟨10.1098/rsta.2019.0169⟩. ⟨hal-03027187⟩
Number of fulltext
994
Number of reference
1 379
Submissions evolution
Submissions distribution by document type
