Hyper-reduced arc-length algorithm for stability analysis in elastoplasticity - Matériaux (MAT) Accéder directement au contenu
Article Dans Une Revue International Journal of Solids and Structures Année : 2021
H. Launay
  • Fonction : Auteur
Jacques Besson
David Ryckelynck
In this article an “hyper-reduced” scheme for the Crisfield’s algorithm (Crisfield, 1981) applied to buckling simulations and plastic instabilities is presented. The two linear systems and the ellipse equation entering the algorithm are projected on a reduced space and solved in a reduced integration domain, resulting in a system of “hyper-reduced” equations. Use is made of the Gappy proper orthogonal decomposition to recover stresses outside the reduced integration domain. Various methods are proposed to construct a reduced bases, making use of simulation data obtained with standard finite element method and a stress-based error criterion for the hyper reduced calculations is proposed. A “greedy” algorithm coupled with this error criterion is used to generate intelligently full standard finite element simulations and enrich the reduced base, demonstrating the adequacy of the error criterion. Finally, numerical results pertaining to elastoplastic structures undergoing finite strains, with emphasis on buckling and limit load predictions are presented. A parametric study on the geometry of the structure is carried out in order to determine the domain of validity of the proposed hyper-reduced modeling approach.
launayEtAl2020.pdf (1.94 Mo) Télécharger le fichier
hal-03088229 , version 1 (25-12-2020)
Copyright (Tous droits réservés)
H. Launay, Jacques Besson, David Ryckelynck, François Willot. Hyper-reduced arc-length algorithm for stability analysis in elastoplasticity. International Journal of Solids and Structures, 2021, 208-209, pp.167-180. ⟨10.1016/j.ijsolstr.2020.10.014⟩. ⟨hal-03088229⟩
4648 Consultations
91 Téléchargements
