A multi-scale strategy to predict fretting-fatigue endurance of overhead conductors - Matériaux (MAT) Accéder directement au contenu
Article Dans Une Revue Tribology International Année : 2020
Georges Cailletaud
C. Yang
F. Hafid
  • Fonction : Auteur
Overhead conductors enduring aeolian vibrations are subjected to fretting fatigue damage. To predict the fretting fatigue cracking risk along the conductor-clamp assembly involving a multitude of crossed-strands contacts, a multi-scale analysis is considered. First, a global model provides the spatial distribution of normal, tangential and fatigue loadings for every contact. "Specific" loading cases were simulated using a local FEM model involving a Crossland fatigue stress analysis and a critical distance approach to correct the stress-gradient effects. Mono-contact fretting fatigue experiments were then performed reproducing the exact same loading cases. The comparison between numerical predictions and experimental results showed that a very good prediction of crack-nucleation is achieved using this strategy. However, total failures were not systematically observed. It is believed to be related to the manufacturing process. Wire drawing induces a longitudinal microstructure which promotes cracks with a low diving angle, rather than cracks propagating directly into the bulk. 3Dsurface-crack simulations confirm a crack arrest phenomenon induced by the contact-induced compressive stress field.
2020_1_PROOF_SAID_TI_143_A multi-scale strategy to predict fretting-fatigue endurance of overhead conductors.pdf (2.93 Mo) Télécharger le fichier
hal-03093081 , version 1 (03-01-2021)
J. Said, S. Garcin, S. Fouvry, Georges Cailletaud, C. Yang, et al.. A multi-scale strategy to predict fretting-fatigue endurance of overhead conductors. Tribology International, 2020, 143, pp.106053. ⟨10.1016/j.triboint.2019.106053⟩. ⟨hal-03093081⟩
35 Consultations
88 Téléchargements
