Characterization and modeling of nanoporous carbon structures - Ecole Nationale Supérieure des Mines de Paris - Theses Accéder directement au contenu
Thèse Année : 2014
Caractérisation et modélisation de structures carbonées nanoporeuses
The aim of the work presented here is to optimize nanoporous carbon materials by means of 'virtual material design'. On this length scale (~ 10nm) Focused Ion Beam – Scanning Electron Microscopy Nanotomography (FIB-SEM) is the only imaging technique providing three dimensional geometric information. Yet, for the optimization, the pore space of the materials must be reconstructed from the resulting image data, which was a generally unsolved problem so far.To overcome this problem, a simulation method for FIB-SEM images was developed. The resulting synthetic FIB-SEM images could then be used to test and validate segmentation algorithms. Using simulated image data, a new algorithm for the morphological segmentation of the highly porous structures from FIB-SEM data was developed, enabling the reconstruction of the three dimensional pore space from FIB-SEM images.Two case studies with nanoporous carbons used for energy storage are presented, using the new techniques for the characterization and optimization of electrodes of Li-ion batteries and electric double layer capacitors (EDLC's), respectively. The reconstructed pore space is modeled geometrically by means of stochastic geometry. Finally, the electrical properties of the materials were simulated using both imaged real and modeled structures.
L'objectif de la thèse présentée ici est l'optimisation de matériaux carbonésnanoporeux au moyen de la “conception de matériaux virtuels”. En ce qui concerne cette échelle de travail (~ 10nm), la Nanotomographie FIB-SEM est la seule technique d'imagerie donnant accès à une information sur la géométrie tridimensionnelle. Cependant, pour l'optimisation du comportement, l'espace des pores doit être reconstruit à partir des données tirées des images obtenues. Jusqu'à présent ce problème n'était pas résolu. Pour pouvoir le maîtriser, on a développé une simulation d'images FIB-SEM. Les images FIB-SEM simulées peuvent être utilisées pour la vérification et la validation des algorithmes de segmentation. En utilisant les données d'image simulées, un nouvel algorithme pour la reconstruction de l'espace des pores à partir des données FIB-SEM a été développé.Deux études de cas avec des carbones nanoporeux utilisés pour le stockage d'énergie sont présentées, en utilisant les nouvelles techniques pour la caractérisation et l'optimisation des électrodes Li-ion de type EDLC'S (« electric double-layer capacitors », soit supercondensateurs). L'espace des pores reconstruit est modélisé géométriquement à l'aide de la géométrie stochastique. Enfin, on a simulé les propriétés électriques des matériaux enutilisant des structures modélisées et simulées.
2014ENMP0073.pdf (21.11 Mo) Télécharger le fichier
tel-01144744 , version 1 (22-04-2015)
  • HAL Id : tel-01144744 , version 1
Torben Prill. Characterization and modeling of nanoporous carbon structures. Image Processing [eess.IV]. Ecole Nationale Supérieure des Mines de Paris; Universität des Saarlandes. Naturwissenschaftlich-Technischen Fakultät III (Saarbrücken), 2014. English. ⟨NNT : 2014ENMP0073⟩. ⟨tel-01144744⟩
413 Consultations
473 Téléchargements
