State-of-the-art laser adhesion test (LASAT) - Laboratoire brestois de mécanique et des systèmes Accéder directement au contenu
Article Dans Une Revue Nondestructive Testing and Evaluation Année : 2011
Laurent Berthe
M. Arrigoni
M. Boustie
Grégory Fabre
  • Fonction : Auteur
  • PersonId : 1136592
Vincent Guipont
This paper proposes a state-of-the-art laser adhesion test. It consists of testing material interfaces with laser-driven shock wave. Since the first demonstration in the 1980s by Vossen, many studies and developments have been done. This paper presents recent experiments and developments on the basic physics involved. Results show the ability of the technique to perform a quantitative adhesion test for a wide range of materials and configurations. Edge effect principle and ultra-short shock wave give perspectives for new applications for multi-layer combination of material. Fundamental principles are evidenced through experiments on bulk ductile materials before demonstrating their application to coated systems.
Mots clés
Matériaux
PIMM_NTE_2011_BERTHE.pdf (1.06 Mo) Télécharger le fichier
hal-00652904 , version 1 (20-07-2020)
Laurent Berthe, M. Arrigoni, M. Boustie, J.-P. Cuq-Lelandais, Cédric Broussillou, et al.. State-of-the-art laser adhesion test (LASAT). Nondestructive Testing and Evaluation, 2011, 26 (3-4), pp.303-317. ⟨10.1080/10589759.2011.573550⟩. ⟨hal-00652904⟩
641 Consultations
353 Téléchargements
